Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Posted on Apr 28, 2017
Kenmore He3 11044832 in handwash mode light keeps blinking. Tried unplugging for a day and it"s still the same. looked for the manual, seen the plastic packing but no manual in it. What could be the possible problems? To make things a little worse I noticed the strike had a crack in it. couldn"t of been that because it"s still mounted solid to the door. But I took a screwdriver and closed the latch figuring maybe the door just wasn"t being read it was closed. Now the washer is still not working and I have the door stuck in an open position.
5 Related Answers
Anonymous
  • 447 Answers
  • Posted on Oct 01, 2007
SOURCE: Kenmore Elite HE 5t washer ( 7 months old)
hmm there is no f21 code there is a F02 code which means the washer is not draining which seems to be what you describe. Did you take the front axcess cover off and check the pump sump area?? Also check to see if the drain motor hums when drain/spin is selected if no hum and motor sits there and no blockage in trap you either have a faulty drain pump or main control board. Washer is still under factory warranty at 7 months so call whirlpool and they will send a tech out. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
A
Anonymous
  • Posted on Jan 28, 2008
SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Anonymous
  • 63 Answers
  • Posted on Nov 14, 2008
SOURCE: kenmore elite HE3 front loader door cracking and broken latch problem
there around 300.00 1 ideal to share buy service smart agreement from sears all parts &labor will be covered up to 500.00 i have warranty it payed off big time
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Jan 04, 2009
SOURCE: Kenmore HE3 lock latch stuck with door open
ok nice details..all you can do is replace the lock latch,,its not to costly,,change the catch while your there,,,lock part number is,,8181700 and catch part number is 8181651..it will be better just to replace it in the long run ,,,onthejob..
Phoebe112
  • 9 Answers
  • Posted on Feb 14, 2009
SOURCE: Kenmore Elite 10.4708 front load washer won't start with new load
Uh oh! It did it again! This time I had to unplug 6 times for one cycle. Seems to be on the last 2 minutes most of the time. Today my husband is taking the control unit and looking for soldering problems. On Askmehelpdesk.com this man told of taking the bottom panel off and there is a little black latch thingy you pull to open the door lock manually. Also he said that the K2 and K4 relays are usually the problem if it isn't a soldering issue on the connectors. ( On the CCU);. He said one of them is usually burned and to clean it off and then switch it with the other one which carries less voltage, therefore doesn't burn. You can use a pencil eraser to do this. My husband told me they did this in the Army for MOose code contacts. He just told lme the soldeirng looks good on the connectors and is now working on the K2 and K4 relays. If you go to Askmehelpdesk.com/appliances you will see these tips are for the Whirlpool Duet whic is apparently the same machine as our Sears Kenmore H4's. Gosh, I hope this helps someone as it sure is not fun trying to track this problem down. I am glad you got Sears to come out. I will NEVER and I repeat NEVER buy from Sears again! Did I mention I wrote a letter months ago when I was having a hard time getting warranty work done.( Which I never did) that I had written to the pPesident, CFO and the Texas Attorney General for Consulmer Protection Division and never got a response from anyone?
Display blinking, but unit will not turn on.
It look like its a Philips turbo drive the power supply itself can having 1 or 2 bad capacitor(s) a broken intake is the most common part in this drives but it look like powersupply or a dirty mode select switch, but beware on marketing technical differences between the models for ordering parts this is not the rca manual and only to compare to this philips turbo chassis but the most critical parts can be equivalent if click the link on the screen down the picture search for the word processing be patient it should change to Get Manual Elektrotanya for electronics experts
2answers
1helpful
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 • Dishwashers
4helpful
2answers
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
2answers
9helpful
3answers
Hitachi power light blinking
Does anyone know how to fix this very common Hitachi problem without paying a repair man? And if you did pay a repair man did they fix the problem, and how much was it? I absolutely LOVED this TV before this happened. :(
4answers
Wont power up, red blinking light (on timer)
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
Alexander
vince
