Broiler element burned out the other night and actually burnt apart. I pulled the plate off the front but still couldn't get the model number off due to age. I took the element to the local parts/repair shopand they gave me a replacement. When i went to hook the new element up, i noticed there were 3 wires, not two. I had taped the left and right wires seperately to the back of the cavity, so i hooked them back the same way. two dark wires to my right facing the stove, 1 white wire to my left. There is still no heat from the broiler element. Bottom element still heats.
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
