When i try to record video, htc touch errors out and says "unable to start recording video. unable to create video file".
i have done both a soft and hard reset. I have removed videos; the battery is charged.
any ideas? i can't find anything on the web about this yet.
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
SOURCE: Using HTC Touch as modem via USB
Go here: http://www.isyougeekedup.com/how-to-enable-internet-connection-sharing-on-sprint-htc-touch-pro/ it worked for me. You need a registry editor to make changes to the Phone, try using this one instead: http://www.mydigitallife.info/2008/06/24/ceregeditor-free-desktop-based-registry-editor-for-windows-mobile-and-ce-pocket-pc-devices/, and as a personal note of precaution, make a full registry backup BEFORE you do any changes.
SOURCE: i have problem with vodafone gprs settings on my phone(htc touch)
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Regards.,
Jay
SOURCE: Using HTC Touch 2 as modem for laptop
First of all you need to install the Microsoft ActiveSync (for windows XP) or WIndows Mobile Device Center (for Windows Vista) After that open the Internet Sharing, select USB and click on Connect. Now connect your USB cable to the Laptop, it shall install the drivers automatically, wait for a few minutes and after that you can use the Internet on the laptop via your phone.
Download ActiveSync:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
Download Windows Mobile Device Center:
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Please rate.
