Sony Ericsson K850i  Mobile Phone Logo
Posted on Dec 22, 2010
Sony Ericsson w959 screen damaged, from bad repair at a shop. Pixels become black/discoloured when i press the buttons at the top half of the phone, then suddenly the left side of the screen went completly black
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
330
Points
Sony 595 heating problem
2helpful
2answers
How to unlock my w20
To unlock the Sony ericsson W20 You can use the unlock code,You can get the unlock code and instructions from here
Theunlockspot.com
and Unlock it from Network lock,You can enter the code using the instructions below:
Sony Ericsson W20 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W20 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W20 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W20 without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
1helpful
2answers
Sony Ericsson w760i black screen, just the keypad light working
The LCD has probably gone out. A new lcd and be ordered on ebay for about $30. Or your local repair shop should be able to repair it for around $60 - $70
When I put on my phone a bright white light comes on
if the lcd become white screen but the phone is working it means the flex cable of your phone is damage and need to replace, but if the phone not work with white screen your phone is in need to reprogam.go to cellphone repair shop.
2answers
I HAVE A SONY ERICSSON W580I...i dropped my phone about 30in high..on hard solid floor...it turns on the buttons light up...everything sounds normal...beacuse i cant see anything..the screen is just...
Probably not easy or cheap. However, my wife broke the flip on her w580i and e-mailed Sony Ericsson and they sent her a new one free. Try e-mailing them or calling them if their site has a number -- it couldn't hurt.
2helpful
2helpful
2answers
Sony Erricson z550i Phone display not switching on!!!
in most cases the fibre ribbon gets worn out.
you can try a local cellphone repair shop, or sony service if you can afford it.
the ribbon needs to be replaced.
Sony Ericsson Walkman does not start
AlinaB hello,
Where do you see the red light? On the screen itself?
Sometimes this problem occurs because of bad battery contact.
Try to remove the back cover by pressing it, and gently sliding it outwards.
Afterwards, remove the battery using your nails or something soft.
Beware not to break any plastics.
Try and using some pressurized air to clean the contacts, and maybe dust and debris that has accumulated inside.
Then, place the battery back, with the restrictions drawings side up. close the lid, and restart the phone.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
