Cell Phones Logo
Posted on Jul 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory card problem with LG NX550
Hay i jst bought an LG NX550 (groove) and when ever i try 2 access the memory card it says memory card error,please reset phone. any ideas whats going wrong? are there any ways of reformating the the memory card without a memory card reader
  • Anonymous Feb 19, 2009
    same
Damen Wong
Level 3:
President:
  • Master 1,950 Answers
  • Posted on Jul 04, 2008
Damen Wong
Master
Level 3:
President:
Answers
1950
Questions
0
Helped
1027272
Points
5739
Go into the settings of the phone to reformat card.
Jst bought a new x3 suddenly my phone jst freezes what i can i do
The first thing you need to do is to check the memory card.If it is infected by virus or the size of the card is more than 1GB,this problem occur frequently.So, try to reboot the phone without inserting the memory card.Good luck
5helpful
2answers
3helpful
2answers
Doesn't have access to memory
if formating your memory card does not work you need a new memory stick
1helpful
Memory card reader
Try format the card using FAT (not FAT32 or NTFS).
5helpful
External memory card for LG kc550 won't work
I was also getting bad format error on my LG kc550. Did a little research (read the instruction book) and if you want to properly format your card to work with the phone you must insert the card into the phone then connect the phone to your computer via the USB cable supplied. Go to "My Computer" and you should see that the phone and memory card are displayed as two separate external devices, when you try to access the memory card your computer should ask you to format it. Click Ok and a Format box will come up, click Ok again and your computer will format the memory card acordingly.
Unfortunatly this resulted in my losing 4gb of space on the card, i dont know wether its based on percentage or a fixed amount the phone needs but if thats the case you will need more than 4GB for your card to be formated for your phone
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Memory card I?O error
just try to format your memory card from computer and then try it will work
3helpful
4answers
64mb to 2 G memory stick dou
The 2 GB memory stick should work in your P990 and not cause any noticeable slowdown.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
