Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to
timer-black-wire and
timer-red-wire. Choose either one for now.
2)
In back of electric box are white wires twisted together and covered
with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then
connect timer-white to bare ground, along with timer-green wire.
4)
Turn on electricity, and push override button located below the OFF button. If lights come on, timer
is wired correctly. If lights do not come on, then reverse timer-red
and timer-black wires.
Add a comment if your need more assistance.
Testimonial: "Geno, Thank you so very much. I finally got around to install one of the two fan switches and your advice was awesome. "
Kyle design shows toggle/decora plate on size chart F 800-551-5953 :http://www.kyledesigns.com/product/SWITC... They also show Toggle/GFCI under 'combo plates:'http://www.kyledesigns.com/product/SP_WH...
http://www.google.com/products/catalog?q... decora switch plate cover
It's a little late, I know, but I would love to hear an explanation for this...
"2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire."
If the white wires at the back of the box are what powers the timer, how can the timer possibly work if those wires aren't there and one connects the timer-white to just the ground wire?
Will these timers work with a newer central exhaust system, in place of the bathroom fans. Thanks Paul
Geno,
thank you so very much for your assistance. I completed one of two timers and works great, I just need to find a two switch plate cover for a regular light switch and this Woods Ind 59008 Digital Time unit.
Happy Holidays.
