SOURCE: windows xp
hey budy me aso treated this sort of problem in recents with some of mine clients..buddy this is a virus attack which is common now a days...mccaffe update of july season is helpful to iradicate that one for sure..n please remove the zone alarm n go for it.it will work for u.
gud lukkkkkkkk
SOURCE: connection problem 81003004
unenstall and reinatall. If that dosent help then shoot it andget a new one.lol I have had the same problem before. Uninstall and do a compleet maintence. Disk Clean, Defrag, Disk Errors..ect and them reenstall yahoo messanger. you can also got to yahoo and donload the latest messanger and update your exsisting one. The 3004 means that your might be out of date and need to update. If you have had this computer sence 2004 or earler you might just be out of date...Good luck.. And if this dosent work i have a Rifle you can barrow.
SOURCE: internet connection
ok, well give this a shot then. But is it possible that the other computer is connected to a network called Belkin?
It is also possible that MAC address filtering is turned on on the router so it will not let your computer connect. if it is, you will have to add your mac address (00-1A-73-DE-12-D5) to the approved list of MACs.
Anyway, you can try manually setting your IP address.
and see if that gets you on. If it doesn't, and MAC address control isn't the problem, then either you have a driver problem or your laptop and wireless router hate each other desparately.
IP address - 192.168.2.199
Subnet mask 255.255.255.0
Gateway - 192.168.2.1
DNS Server - 192.168.2.1
This will force you computer to get network settings that match the netowrk. But beware, this will affect you if you try to go another network. You will then have to switch back to automatic configuration. but if you set up these settings and still can't get on, there is something wrong with the driver configuration. But make sure that there isn't another network called belkin.
If the manual configuration doesn't work, try updating the wireless driver from the manufacturer's website. Also try connecting to a wireless hotspot somewhere else and see if it is a computer problem or a problem with this specific wireless network.
Post back if you need anything further, I'll hang in with ya as long as I can.
To solve this kind of network connection in your yahoo messenger, just click on your yahoo messenger, select the connection preferences in the menu and then select the proxy server as the connection preference other than the internet one. then select from either the dial-up, broadband or the high speed t1 lan connection. it's up to you how you connect.
it works for me. hope this can help you.
cheers,
argion
SOURCE: Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
