As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced.
On both sides of the valve are 2 smaller screws. these are the water shut off valves.
turn off the water and remove the larger screw fitting. remove spool and replace.
Hope this helps.
