I have a Yardman electric leaf blower/vacuum #YMESV1300 and need to replace the impeller. (Old one has a piece broken off). I ordered the part on line and wonder how to get the broken one off (after unscrewing and opening up the blower)?
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
google for sources. In the 80's i was employed by a co that probuced brushes according to specs. We received them in bags, or envelopes, etc. If you cannot find them through the orig. mfgr., send the remaining brush or the holder, with as much of the brush as is remaining for proper dim. estimate and brush composition. some brushes have the composition of dry charcoal. while some such as "EGO" can substitute for a very soft pencil.
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
I have not heard of one for that unit. Plus I would not use it for vacuuming any way. All you need is for an acorn or piece of wood to hit the impeller. It would break a couple of fins off the impeller. This would make the blower vibrate like crazy and you will not want to hold on to it. Plus the cost of repairs would exceed the cost of a new one. Good Day.
I would advise not using it to vacuum with. The impeller/fan is made of plastic and when an acorn or small piece of limb hits the impeller, it will break off the impeller blades. You would then have to replace the impeller because the unit would be off balance and vibrate like crazy.
