Expert
- Posted on Dec 21, 2010
Re: How to install new door spring on portable dishwasher
Things You'll Need:
Owner's manual
Screwdriver
Replacement spring (optional)
Turn
off the power to your Kenmore dishwasher before attempting any repairs.
If you have a portable Kenmore dishwasher, you can just unplug the
power cord from the wall. Built-in dishwashers are hard-wired into the
cabinet, so you will have to turn off the breaker switch at the home's
circuit breaker box to cut the power.
Remove
the screws that hold the kickplate onto the lower front of the Kenmore
dishwasher. Take the kickplate off to access the door springs.
Check
the door springs to make sure they have not come loose from the door
support or the adjustment holes on the dishwasher. Re-attach any ends
that have slipped off their connections.
Replace
the springs if they are connected at both ends but still do not have
enough tension to support the weight of the door. Once a Kenmore
dishwasher door spring is stretched out, it cannot be restored to its
original condition. Unhook one end of the old spring from the
adjustment hole. Unhook the other end from the door support and discard
the spring. Insert one end of the replacement spring into the
adjustment hole and the other end into the hook on the door support.
Open
and close the door a few times to make sure the spring is now working
properly. The door should not bounce up and down or sag on the hinges
when it is in the open position.
Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
