It thinks that the SD card is full - try re-formatting if you have no photos there. The SD functions the same as a PC hard drive, and if the directory 'tracks' are corrupt, anything could happen. Else try a new SD card.
Hi
Have you tried resetting the camera back to factory settings? This should clear up any problems...if it doesn't it may at least let you know what the problem is? Also...do not use an SD card no bigger than 2 gigs, What is thee display showing? Make sure the date and time are correct! Get back to me if you need any more help...Thanks...John,
Contact Nikon tech support at www.nikon.com to see what they recommend. I don't think the warranty covers abuse such as dropping the camera so you may be in for an expensive repair. However, he Nikon techs may be able to suggest something that might help you avoid that expense.
The SD card has nothing to do with your problem. Make sure that the battery is good; i.e., it is both taking and holding a charge. If you have a voltmeter, look at the back of the battery just under the three electrical contacts. You will see that they are labeled "-", "S" and "+". After charging the battery, measure between the "-" and the "+". It should measure 8 volts DC. Then measure between the "S" and "+" and it should also measure about 8 volts.
Next, you need to see if a short circuit in the camera is loading down or draining the battery. Put the battery in the camera. Keep the camera turned off and leave it overnight or for a day and remeasure the voltage. If it has dropped more than a 100 mv (0.1 volts) the problem may be with the camera. If that is the case, you will need to send it in for repair.
The D50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will only work with devices specifically designed to accept SDHC cards. The D50 wasn't. It only works with SD cards, 2GB and smaller.
Do you mean the camera can't works well with your new Nikon D50 battery?
But how about your original battery.
Maybe your new battery is not so compatible with your camera so the camera can't recognizes the whole information on the Nikon D50 battery chips.
There should be a "format card" option in the camera's system menu. do this and it may help the unfortunate equipment realize the situation:) (be sure there are no pics you want to keep as they will be permenantly removed)
Error message "full" but emptied memory card
