If water leakage occurs: • Check to be sure the tank cap is tightened properly. • Check the tank for leaks and replace if necessary.Check the water valve and water tank cap.If the valve or cap any of this is loose the water will leak. Fill the Water Tank with clean, cool, tap water and replace the Tank Cap by firmly turning clockwise. Turn the tank upright and check Tank Cap for leaks. If any water drips from Tank Cap, remove it and re-tighten. Make sure the circular rub cap Gasket (o-Ring) is in place when replacing Tank Cap - this prevents water leakage. ------------This should help.Thanks.Helpmech.
