Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
Posted on Aug 08, 2017
Having a major issue with brand new Napoleon pellet stove insert. it has broke 3 times with the same problem and havent even had it for 1 year. The auger motor goes bad. this is a model np145. I work as a heating and air tech and it seems to me that something is causing the motor to go bad. they keep replacing it and then in 6- 8 weeks it stops working. is this a common issue? what do i do?
2 Related Answers
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 01, 2009
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 08, 2009
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Why is my reset switch popping after 10 minutes when I try to to start the pellets.
I would suggest contacting Napoleon directly at 1(800) 461-5581 and ask for a registered Napoleon service dealer in your area. You can also go to this website http://www.napoleonfireplaces.com/find-a-store/ and ask them if they have a service technician if you are in the United States. Pellet stoves are extremely temperamental and can be a real bear to try and diagnose. Honestly, leave the diagnosing and troubleshooting to guys that have meters and gauges to properly diagnose the issue. I hope this helps.
My auger on my napoleon pellett stove got noisy and then quit working. Is there a reset button and how do I find it and get it to work? I already gave my credit card information and was not able to chat...
Did i sound as if the auger got jammed when you first heard this noise? Or was the stove overheating? Have you changed the brand of pellets recently, from what you had been using? These are just a few of the things that can cause a pellet stove auger to stop working.
Yes, there is a reset switch, but since you didn't mention which model Napoleon Pellet Stove you have, it's hard to know where to tell you it is.
However, most Napoleon stoves are very similar in how they work and their mechanics. So, I have included a link to an Owners Manual for the NP140 Model. This should point out the things I mentioned, as well as other causes and how to solve them. Be sure to check out the Trouble Shooting Guide.
http://www.napoleonfireplaces.com/Tech/installation_manuals/NPS40_NPI40.pdf
You can download and print this manual if you like.
If you weren't able to chat with someone about this, you want be charged the Chat rate.
Hope this helps head you in the right direction.
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Smoky smell from Napoleon pellet stove.
it over fueling at low setting this is a comon problem and will do exsaclly what you have said
2helpful
5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Top Napoleon Pool & Spa Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
