Question about Patton PRH11 Electric Heater
My patton prh11 heater keeps acting like its going to come on for maybe about a minute or so and then actually comes on. It just keeps turning on and off constantly. Maybe about 15 times in a minute.
    Novelist:
    Champion:
  • 224 Answers
These heaters all have safety devises in them some for tip over and all for over heating. Your problem sounds as if it has a bad over heating sensor. These will have two wires one in one out, it is usually a positive wire. When they sense that the heater is to hot it shuts it down upon cooling it allows the heater to turn back on. The tip switch does the same if upright it turns on if tipped it turns it off. They are mechanical and thermal switches and they do go bad. These can be jumped out to trouble shoot the problem but I would not run it with out these safety devices in it.
Posted on Dec 21, 2010
SOURCE:
Beep to often
the beeping could be caused by the tip switch malfunction. The best thing to do is call for a warrentee replacement @ https://secure.pattonproducts.com/ContactUs.aspx
Mar 02, 2011 | Patton PRH11 Electric Heater
My heater makes a buzzing sound when u turn it on.
May be loose screw in frame, element is old or insulator is worn
Jan 10, 2011 | Patton PRH11 Electric Heater
How do I open my PRH11 heater to clean the senser?
I just used an old toothbrush and stuck in in between the grate holes on the front. I Just brushed on and around the sensor really well & it seems to be working fine now.
Dec 12, 2010 | Patton Electric HRH316 Ceramic Mid-Size...
Patton PRH11 Buzzer Sounds on HIGH after 2 minutes
There is a round sensor under the heating elements which sets off the alarm when it thinks it is overheating on the PRH11. Unfortunately, a dirty sensor will fool it into reacting like it is overheated. I cleaned the sensor which was dark and revealed it to be a lighter goldish maybe brass in its original color. If your sensor is dark, it will continue to trip the alarm for overheating and will need to be replaced. If you were lucky like I was and can clean it, the problem should be resolved and it will operate like normal until it gets dirty again. This procedure lasted for 3 days and I had to clean it again. I believe I left the dirt on too long and now my sensor has tarnished plus I live in a rural area with significant dust requiring this recleaning every few days. I only used a damp paper towel with water to clean. Cleaning may work better with alcohol or a tarnish removal solution.
Dec 09, 2009 | Patton Electric HRH316 Ceramic Mid-Size...
Patton POH2520-U heater not working
I have a RD125T heater. At first it would run for a while and shut down. Turn it off and back on it would do the same. Now when it is turned on it acts as if the switch was being turn off and on. Sometimes the heater will fire for a second then shuts down. Most of the time it just shuts down, Forest
Jan 30, 2009 | Patton POH2520-U Oil Filled Radiator...
The Patton heater model prh11 doesn't stop running
Either the air entering the heater is to cold and unable to satisfy the thermostat or the contacts inside the thermostat have “welded” together, or other faulty internal wiring which could keep the heater running indefinitely. Take it back to where ever you purchased it from or throw it away, that could be a fire hazard.
Hope this helps.
Dec 02, 2008 | Heating & Cooling
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
Jan 05, 2008 | Patton Electric Patton PUH680-U Electric...
Patton PRH11 Electric Heater Logo
982 people viewed this question
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ray gallant
ray gallant
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
