Archos 5 Internet Media Tablet Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Archos 5 intermediate tablet will not sync to my computer it is not even recognised as a device can you help
J.a Vijay
Level 2:
  • Expert 51 Answers
  • Posted on Dec 21, 2010
J.a Vijay
Expert
Level 2:
Answers
51
Questions
0
Helped
4998
Points
155
Check connection settings if anything is blocking open all the settings
Archos 18c vision mp3 will not charge
I think the USB cable is defect, or one of the connectors, on the tablet, computer or even on the cable. First try a new cable and check if nothing is in any of the connectors, like dust or other debris.
2helpful
How to Itunes song onto the Archos 28.
You can connect you Archos to you computer by the USB cable which have came along with the tablet.
From tablet you need to choose mass storage device when you connect the cable. Once Mass storage activated you will see your tablet or SD card on your computer. You can copy paste or drag and drop songs from your computer folder to archos tablet Music or Media folder.
Or
You can use various Sync application from Android Market. Below given link is to list of applications available on Market. Please read description before you purchase or install any application.
https://market.android.com/search?q=itune&so=1&c=apps
Cannot connect to computer via lead. will not enable via usb port. has worked perfectly up to now. unable to sync files to archos because of this. help.
Maybe your drivers on the PC have become corrupted for the Archos...try uninstalling them and re-downloading them from here.
http://www.archos.com/support/support_tech/updates.html?country=au&lang=en
Was downloaded, reinstall, see if that fixes your problem.
1helpful
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
2answers
After formatting the archos5 ,the device doesnt get recognised
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up, just pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
17helpful
5answers
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Syncing my Windows Media Player playlist over to a 605
PROBLEM SOLVED!
Go to the Archos website and type in your model number - my case 605 WiFi - and it shows you a list of firmware downloads. Just click to download the latest firmware update which you should save in your desktop - it's about 45Mb-. Once te download is complete open My Computer on your PC and click on teh Archos icon which takes you to internal hard drive icon, click on this icon and paste the update (aos) file from your desktop into this level of teh Archos - Don't paste it into any of the folders as it wont work!
When you disconnect your Archos from your PC it will display that it has found an update and would you like to install it, click on Yes and Voila! WMP playlist will now sync properly to the Archos!
Hope this helps you teh way it helped me.
Cheers
Keith
1helpful
3answers
Archos 404
Archos is not claiming compatibility with vista, even with their latest firmware upgrade - sorry
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
