Sewing Machines Logo
Posted on Dec 21, 2010
Can I use a twin needle on my Janome MW3018? Doesn't mention it in my instruction manual and I don't know how to thread the machine for twin needle sewing.
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Dec 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1702
Points
21
Twin needles can be used on any machine. Just make sure you use the correct presser foot......one that allows both needles to work without hitting the foot. Also.........you cannot zig-zag or use any other fancy stitch with a twin needle.......it is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
  • Anonymous Apr 08, 2011
    I like hemming knits with a twin ballpoint needle. Some computerized machines require a offset twin needle so good to check manual for yr machine.
1helpful
Can you coverstitch on janome 644d? How do you do it if you can?
Here's a manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiup8_ajMXaAhUBpYMKHR6qC5IQFggnMAA&url=https%3A%2F%2Fwww.janome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fretired%2Fserger%2Finst-book-644d.pdf&usg=AOvVaw1V_Sa4aOT_SSPyhJnTYgIa
Offhand, I'd say your machine is most likely an overlocker only. A combination overlocker/coverstitch usually has 5 threads, there is also a way of converting it from one to the other, the manual doesn't appear to mention anything about coverstitch.
You can, however, replicate a coverstitch by using a twin needle on a sewing machine.
Can I use a twin needle on Janome Sewist 500? I have tried and the threads keep getting tangled, or I get skipped stitches.
Difficult to say. The manual doesn't seem to mention using a double needle. However, frequently, the the bobbin loads from the top or the front, there is a possibility a double needle will work.
Be sure you are using the correct needle and thread for your project. Use a ball-point for knitted fabric. Also, be sure to thread one top thread all the way through the needle and then thread the other thread. Do not thread them at the same time as the threads will twist. If your machine has separators in the thread path for separate threads, be sure to separate the threads. (Most likely your machine does not have separators since there is no mention of using double needles.) ALWAYS THREAD with the presser foot raised.
Janome 525S Instruction Book Changing Needles Needle And Thread Chart
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiawf-507_RAhVHwlQKHQrnAXgQFgg4MAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
1helpful
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
How do I thread to use twin needles on Janome Excel Pro 5124?
here is a link for a manual, the information should be in it about the twin needles Instruction Manual Janome 5124
Thread a twin needle
The same as a regular needle a twin goes in the same. it has only one stem 8_29_2014_5_48_42_am.jpgnotice above the read is on stem this goes into the same area as a regular needle.
2answers
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
3helpful
Howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
