Lasko 5132 Ceramic Compact Heater Logo
Anonymous Posted on Dec 21, 2010
The lasko ceramic element fell over, and stopped working. After setting it upright I attempted to turn it back on. The heater will only beep after i press the power button.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6582
Points
Unplug it for 5-10 minutes. Then try again, worked for me. Plus it says to do so in the back of unit! Hope this helped
  • Dinh Han
    Dinh Han Mar 16, 2021
    I dropped it. Unplugged for 15 minutes and it worked again. Cheers!
Anonymous
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Dec 21, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
121140
Points
598
The quartz heat tube evidently cracked. you'll need to replace the element.
My Lasko Ceramic Heater is beeping every 5 second, how can i get it to stop?
It sounds like the beeping and flashing issue on your Lasko Ceramic Heater might be related to the clock setting. Here's what you can try:
Unplug the heater for a few minutes to ensure it's completely powered off.
While it's unplugged, try to reset the clock to the correct time by pressing the appropriate buttons on the heater's control panel. You might need to refer to the user manual for specific instructions on setting the clock.
After setting the clock correctly, plug the heater back in and see if the beeping stops.
If the issue persists, it's a good idea to consult the user manual or contact Lasko customer support for further assistance, as there might be a specific sequence of buttons to reset the clock or troubleshoot the problem.
I have a Lasko 5141 Ceramic Electric Heater, and when I turn it on, I smell burning and the heater makes a whining noise. I've tried vacuuming it, should I try again or is there another step I should take?
You have an excess amount of lint buildup inside the ceramic element, you need to take the unit apart to clean the element. The fan housing covers the backside of the element and blows the air forward, over a period of time lint builds up.
You need a qualified person to take it apart safely and clean it. It takes a Special Chinese Triangle Bit screwdriver to remove the 2 tamper proof screws from the back. Purchased mine at mcmastercarr.com
Triangle Bits
a7atriangles.png?ver=280340775941a14p1s.png?ver=23707593
These power bits have a 1/4" hex shank and are 2" long.
Size(A) EachTA180.070"5941A11$3.77TA200.083"5941A123.77TA230.090"5941A133.78TA270.100"5941A143.77
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
3helpful
Whenn I turn my Lasko htr model # 5132 on it beeps twice n acts like there is no power. what can I do?
unplug the heater. clean the vents in the back using a vacuum cleaner hose attachment. wait 15 minute and plug the heater back in. This has worked for me.
5helpful
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
3helpful
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
1helpful
2answers
Have a lasko ceramic element heater
just wanted to say that I am having the same problem.  I turn it on and it stops working.  When I push the power, it only lights up for a second and beeps and then goes off.  Is there a solution to this yet? I think the company owes us an explanation.  I have already tried to plug it in to different outlets and still get the same results.
1helpful
3answers
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
2helpful
2answers
Lasko 5132 Ceramic
let me guess it just makes that beep,and doesnt even turn on.get a steak knife or flat head screw driver and scrape all the dust and hair of the steel screen on the back every two months or so.it should work after that.i had the same problem.
Top Lasko Heating & Cooling Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
