Hi there my son put a code in his ipod to lock it and has forgetten it how can i reset it
i locked my ipod by accident and i dont know the code to unlock it.
When connect ipod to computer, go to my computer. Click on ipod:- -click on tools, go to folder options -go to view tab -check show hidden files -a ghost like folder will apear: ipod control -click on it and go to device -there will be a locked file -click and delete it
If you have forgotten the unlock code you can still unlock the iPod using the iTunes software. Connect the iPod to the primary computer that you use to update it. Then, open iTunes and synch the iPod. When you disconnect it from the computer it will no longer be locked.
If you can't remember your lock code on your Nano, you will have to restore the Nano via iTunes, there is no other way around this, as there is no way to recover your lock code. Restoring your Nano will erase everything on the player, and restore it to factory defaults, after this is done you can restore all your files and settings to your Nano. Here is instructions on resoring your Nano in case you aren't sure how. http://support.apple.com/kb/HT1339?viewlocale=en_US
Enable hidden folders.
In Windows Explorer,go to "Tools", "Folder Options". Then click on the
tab called "View", and under "Hidden Files and Folders", click "Show
Hidden Files and Folders".
Navigate ("My Computer" to double-click on the icon of your
attached iPod) to the hidden folder named "iPod_Control", and once
there click on the folder "Device". Once there, delete the file named
"_volumelocked".
Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
Once your iPod has rebooted, check and make sure that it worked.
Simply go into "Settings", "Volume Limit". If it asks for a PIN, you
did it WRONG. Retry the above procedure.
You should be able to reset the ipod by pressing/holding down the center button and the menu button the same time (6-10seconds). If that dosen't work, plug in your device to the computer and you should be able to reset it on the itunes program.
i did the same thing same color:(
