You seem to have everything in spec. check your crossover points and your speaker wiring. subs may be playing out of phase. A huge factor is subwoofer enclosure ...if the enclosure is not in spec with sub requirements the subs will not peform great.
This is an 150 RMS amp, but the ratings say it'll push 2 10's. You probably won't get much out of that amp with a 1230 watt subwoofer. The subwoofer you are wanting to run is 300 RMS, so you'll get half the power you could be pulling. But it would do okay I guess. Nothing like what you could get with a different amp though. You need like a 1000 watt amp to get the most out of your sub. But "YES" you can use them together.
The more amp you are pushing the better. Better too much amp then not enough. How many watts per speaker? less then the amp I hope. When you need decibles the more air you push the louder it will be. Enclose in a MDFB enclosure or plexiglass and feed towards each other and port the box to the sides. This will cause some annoyance. We ran 2 rockforts @1000 watts and abtained 137dc before the back windshield blow out,,lol
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm.
Wiring Option #2
Wiring Option #2
this is for dual 4 ohm coils Wiring Option #2
What kind of speakers are they? Liquid cooled speakers? I am assuming you are working with the bazooka speakers? Honest sugguestion: get different speakers. Bazooka is not that good of a brand. looking at bazooks's webiste the magnet size is only 30 ounces! The only good thing I have seen that have come out of bazooka was way back in the day their "P. Miller" series (a.k.a. Master P) And I never tested the subs, only the amp. What kind of car are you putting them in?
Next, a 4 channel amp is usually designated for the midrange/tweeter speakers. If you want good hard bass, only a mono or duel channel amp will put out the ohms that you need. Remember, you get what you pay for. If you get 20 dollar speakers and a 50 dollar amp, do NOT expect to hang with the big boys, even if the speaker is a 30 inch and the amp claims to be a 10,000 watt. Stay away from sony, stay away from bazooka, stay away from unknown brands.
My ideal set up would be Alpine type R or type X for subs, a Fosgate or memphis amp, and mb quart mid/tweeters. All are readily available, so competition keeps the prices affordable. Look at magnet weight when choosing subs.
Visonik is somewhat low-end car audio and band pass enclosures in general usually produce rather muddy and boomy bass. It will probably sound "bad", but not hot, and not cool.
If you aim is a good self-contained system with amp, sub and enclosure all in one, why not consider an Infinity Basslink, MTX Thunderlink, or perhaps a Bazooka. They're all available at www.crutchfield.com for little more than you'll pay for the Visonik and any of them will definitely sound better.
when bridgeing an amplifier it always sees half of whatever load you have on it, so if you have a 4ohm speaker when it is bridged the amp will see 2ohms, so yes you can bridge the 4 ohm speaker
Well it could be that your ears just got used to the bass. It happend to me after about a week of haveing my subs. And make sure that your power wire hasnt got melted somewhere. also that you have good ground.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
