if the sounds a high pitch squeal !! I had an ole tv that did that when u watched it , finally one day the dang power supply up and gave out !! so that must be what the noise was coming from all that time !!!
DSLReports
Oct 3, 2009 - 30 posts - 7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
That humming sound is a sign that your color wheel is becoming or already is defective. If you don't replace it you might even lose picture in the future since it's part of the light engine system
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
The color wheel is the most common problem in DLPs that cause noise.
To determine the cause:
Turn the set off.
If the noise goes away after about five seconds, then, the problem is the color wheel.
If the noise goes away one to two minutes after shut off, then, the problem is a fan.
You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link:
http://www.samsung.com/Support/ServiceLocations/index.htm
