White Sewing 1735  Sewing Machine Logo
A
Anonymous Posted on Dec 21, 2010
How to set it for straight stitches? I've misplaced my manual when I moved. Patricia D email: [email protected]
Debbi's Sewing Machine Repair
Level 3:
  • White Sewing Master 7,365 Answers
  • Posted on Dec 21, 2010
White Sewing Master
Level 3:
Answers
7365
Questions
Helped
1743851
Points
19451
In the search engine type singer when the singer site comes up look for manuals, & click on the word manuals & in the search box put w1735
the manual is free
1helpful
2answers
Do you have a diagram of the buttons to click on to get the needle position to change in the Pfaff 1473?
The needle position of the Pfaff Creative 1473 can only be changed for straight stitches. Use the stitch width + button (the top of the pair of buttons in the middle of the row below the LCD display) to move the needle from left to right. The range of positions depends on your stitch choice. There are 19 positions available for stitch programs 01, 03, and 04. There are 17 positions available for program 05 (triple straight stitch). The stitch programs are indicated on page 2 (page 6 of the PDF) of the manual. The use of the stitch width buttons is on page 30 (page 34 of the PDF). See pages 50-53 for additional information. Different symbols will appear in the display to show the needle position (to the left, center or to the right).
The manual is available from Pfaff on the product page: https://www.pfaff.com/en-us/machines/creative-1473 . The current link to the manual is https://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf .
I hope this helps.
Euro-pro 9130c. Sewing not moving forward. Stitching in one spot. How do I correct so fabric and stitching moving?
The feed dogs might be lowered, or the stitch length might be set to zero, or the presser foot tension might be very light.by
Check the feed dog lever first.It is at the back near the free arm. If it is ok, test the feed dogs by setting the stitch length to maximum on straight stitch, then, with the presser foot raised and no material or top thread in the machine rotate the hand wheel towards you and watch the feed dogs. They should move up, then towards you then down then back in cycles. If they don't move, and the feed dogs are not lowered, something is broken https://www.manualslib.com/manual/939695/Euro-Pro-9130c.html?page=6#manual
2answers
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
How do I turn the selection dial to zigzag on my Elna Super
I've got a Supermatic manual but I think maybe you mean the earlier model perhaps. On the supermatic you set the stitch width to 2 and stitch lenth to 2+ for a zig zag. In this image, the stitch width selector is marked "3" and the stitch length selector is marked "4".
I've got a feeling that on the earlier model you may need to use a zig zag (single) disc in the Elnagraph to get the needle swing function.
As you probably don't have a manual, you may want to join the Yahoo group called Elna Heirlooms as the members there share info on these vintage machines, and some manuals are there.
Go to www.yahoo.com, sign up, then go to "Groups" and search for "elna Heirlooms". You will need to ask the moderator to join the group but once accepted, you'll find lots of helpful information, check out "Files" for shared documents.
Hope this is of help to you.
I have a Singer 367 and it will not do a zigzag stitch. The needle goes from side to side but I end up with 4/5 straight stitches and then 2 zigzags then back to 4/5 straight stitches. The tension and...
Either you have a blunt or bent needle or the needle is in the wrong way round or failing that you may need to retime the machine which is quite likely, if you email me I can attach instructions [email protected]
3helpful
White XL1760 cant find the setting for the straight stitch.....a, b, c????
You can download a manual for your White machine from the Singer website, link is
http://www.singerco.com/uploads/download/1111_white-1760-xl-x.pdf
Here are the relevant pages from the manual:
Straight stitch settings as follows:
stitch length on 2.5 (selector marked with blue arrow)
stitch width on zero (no swinging of the needle) selector marked with red arrow
stitch selector on A - selector marked with green arrow
Generally all sewing machines will have a similar three controls, because all stitches are a combination of moving the fabric forward a certain amount between the needle going through the fabric - the stitch length; and moving the needle from side to side - the stitch width.
And then a stitch selector for different stitch forms such as a blind hem or shell stitch where the needle is going through a series of different moves in sequence to form a special stitch. You still have the width and length controls to vary this formation.
For general sewing machine information www.sewing.about.com is excellent, there is lots of pages on general tips, cleaning, threading up and sewing machine know how. Try this page to start http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machines.--9k/
If you are a beginner, then I'd recommend printing out the instruction manual for your machine and putting into a binder, placing beside the machine, and carefully read from the beginning going through all the instructions to wind a bobbin, thread up, three or four times until you can do it without reading the manual, then practice stitching out each of the stitches your machine does. Buy a cheap exercise book and on each page, write the name of the stitch, staple the stitch sample in and either write down the settings used or glue in a photo taken of the machine controls you used. This way you can quickly flick through and refer to your settings next time. ADjusting the top tension dial will also adjust the stitch formation so read the manual and set the tension dial to the setting it suggests but sometimes you'll need to adjust it slightly to get the stitch looking even (balanced between top and bottom thread), especially for zigzags.
Practice a bit and you'll soon feel much more confident using the machine. Also, refer to the cleaning and oiling instructions and do it regularly, along with changing the needle for each new sewing project, about 4-6 hours sewing time. The needle is the most important part of a sewing machine, always use the right sized needle for the fabric. Refer here for info http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
I hope this helps you with your White sewing machine, there are lots of great sewing machine books on the market too or in your public library to refer to. Also taking beginner sewing classes will really help you learn how best to use your machine. I've been sewing for over 38 years but still enjoy going to a class and learning a new technique from another enthusiast - life long learner!!
Im having problems getting a straight stitch could you give me the proper settings for crushed velvet, and for a regualr type fabric
I would use a 11/75 needle, then a walking foot if you have one. If, you do not, use some gift tissue paper between layers, or stabilizer. Keep your stitches between 10-12 per inch. Regular fabrics, just your usual stitches that your manual recommends. If, you misplaced your manual go to www.singerco.com and download a free one and save it on your computer.
Oct 20, 2010 • Singer 1725
My name is Patricia, I have a brother machine model xl-2230, I have many problems to be able to sew with her when sews very loose coil wire, and that entanglement does not allow sewing thread. Despite this...
Set the tension control to what is recommended in the manual.
Thread the machine with the presser foot up and your stitching should be well formed.
Be sure to use the type and size needle appropriate for the type of fabric than is being sewn.
3answers
Sewing machine straight stitch is not straight
It sounds like it is making a blind stitch, does it look something like this? -----v-----v-----v-----v-----v If so it might be on the blind stitch setting instead of the straight stitch! ;-)
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
