The lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
SOURCE: Bulb Life
The bulb should last for about 2500 hours as per the manufacturers.
Try resetting the timer even without replacing the light bulb. Check page # 49 of the PDF file on how is done.
http://www.aboutprojectors.com/pdf/eiki-lc-sd15-manual.pdf
I would suggest to turn the projector OFF when not in use.
Good Luck.
SOURCE: No power to Eiki EIP-2500 projector
there is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
SOURCE: bulb won't work
If you are sure that you installed the new bulb correctly , then I recommend that you reset your projector . Some projectors don't realize that you changed the bulb physically until you reset them .
please rate !
