Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
If there is a NAPA auto parts store close to you they can also get the primer bulb for you
The comment above about the Zama carb bulbs is correct. Another source for parts that I have used several times ishttp://www.ereplacementparts.com/. They seem to have parts for just about anything. Most of the "primer bulbs" I have seen are interchangeable, standard size, and cheap. Get two or three while you are at it. Gasoline and additives leach the plasticizers from the soft plastic bulb within a year or two and they crack open.
si mi homelite 26b no enciende que tengo que hacer
