Most themostats have a setting that you can switch from Celsius to Fahrenheit. If it is cold I wouldn't mess with it right now. First google the model and see if you can get the manual for it. Some types unsnap from the wall and have setting switches on the back.. other you have to navigate trough the settings program.
Need a model number
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
If [230] appears on the
display screen, then the temperature is set to Celsius. To change back
to Fahrenheit:
1. Turn off your flat iron and unplug from electrical
socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press
& hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the
digital screen. Your device is now in Fahrenheit mode.
