Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
A
Anonymous Posted on Dec 20, 2010
Use sony xbr 32" 1080p 120hz. Connected to bluray
Anonymous
Level 2:
New Friend:
  • Expert 82 Answers
  • Posted on Dec 21, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
82
Questions
Helped
17615
Points
235
YOU NEED TO RESOLDER SOME RESISTORS THAT BECOME LOOSE WITH THE TVS TEMPERATURE... YOU CAN GET A MANUAL TO DO IT YOUR SELF.. AT TVPARTSANDMANUALS ONLINE
How can i register add Sony TDG-BR250 3d glasses to SONY KDL-70W850B 3d tv
Hi Mate
Press the Power Button of your 3D glass for 2 Seconds The Power Goes to Green LED ON now your 3D glass is ready for used. Play your 3D movie from Bluray player and Press the 3D Button on the remote. If there is no 3D button on the remote then press Option Button on the TV remote and choose the 3D option from the list. the video will changed to 3D video Now Enjoy your 3D experience. If you any difficultes then PM me.
2answers
Picture all blurred when playing bluray
Connect the blu-ray player into the HDMI port that currently has sky on it. Does it work then? if so the port you were using has failed. If not the blu ray player has failed.
The bluray disc in our bluray player only plays the reviews and not the movie. Can you tell me why this is happening
You may need to update the firmware for your bluray player especially if this is a newer movie. You should be able to find an option to update under the bluray devices menu that is if your unit is internet capable and connected to your internet.
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Region Code unlock for Panasonic "SA-BT737"
hi my panasonic bluray dvd player sa-bt737 is not displaying the picture, the sound is working great but i cant watch the movie even though i can hear what is going on in the movie. it has worked great in the past but i dont no what has happened please help me
Loaded new blu ray disk today and the player will not recognize Display says "can not operte this disk" tried two new and the same response....no problemes before
try updating the firmware of the bluray. This is one downfall of blueray is that for newer bluray movies it requires new frimware to process the video :)
When the Sony Bluray Player is played, the monitor shows that player is running the bluray disc but nothing on my plasma TV - pitch black. I don't think there's anything wrong with the TV as it has no...
After making sure that you have either connected the player to your TV via HDMI or component video, select the associated input on the TV. If you still have no picture, press the video button on the BDP-S300 remote until you get a picture.
A blu-ray player cleaner will not solve this problem.
Bluray movie playes sound but no picture, HDCP problem?
In order to provide the proper solution to this, I need to know how this unit is connected to the TV. Also, when using the PS3 in game mode, do you get both picture and sound? What is the make and model of the TV involved here?
There are a number of reasons for the loss of picture. I will assume that you have selected the correct video input and video type. But for confirmation, please provide those details as well. Once you update this, I will try to give you an explanation and potential solutions.
Thanks,
Dan
Letter box picture when viewing blue ray discs on Sony BR player
All blu-ray movies are in Widescreen format. So your tv converts the picture to make it look like letterbox. There will be some movies that will have those little black bars at the bottom. There will be some movies that don't. There is nothing to worry about it is normall.
Hope this helps
Help
how are you connected to your tv? if your are connected in HD mode (hdmi cable) you will only get a 16:9 picture... SD mode (AV cable, S VIDEO cable, Component AV cable or SCART) will transmit a picture of 16:9 or 4:3 (4:3 being the old 'square screen' mode)
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
