There may be damaged or broken wire to the evaporator fan
There are two wires to the evaporator, one hot and one neutral Unplug and check the neutral against ground with a continuity tester if ok test the other wire in a non invasive fashion using a safety pin
The way you do is to insert the pin say at several points on the wire until you discover where the break is. Use alligator clips, one is to be connected at the connector of the fan hot wire ( The suspected wire that may be broken) With alligator connected at the end of the wire connector, insert the pin at different points to check wire integrity with an ohmmeter. Where there is no continuity, that is where the break would be.
If that does not work, you probably will have to run a new wire. Here is a hint: The evaporator fan runs only when the compressor is running. If you can extrapolate, you can find an alternate way to reconnect the evaporator fan and have your fridge running in no time.
