SOURCE: Hitachi P42H401 - No Picture or Sound. Some Menus work.
There is a power button on the front and a "main" power button underneath the front panel. Pushing the main power button should reset it.
SOURCE: Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
SOURCE: Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
SOURCE: intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
