When you bleached your hair you removed all the pigment from your hair which is why your hair turned pink. You need to use a color the same level you want to achieve but make sure it is an N ( to put back the primary colors ) this is called a filler. after you rinse and dry then apply the 5RR . it helps to rinse out not shampoo joico color esp the red series then use joico cuticle sealer. don't shampoo your hair for 2 days , it should help with the red fading. always use a filler when coloring bleached hair.
