If the problem is that it loses pressure quickly (that is, you have to pump it up again and then it will light briefly), the problem is most likely the cap. It has a rubber gasket underneath that has probably dried out and isn't giving you a good seal. These caps are common replacement items, all the same size, available at Walmart, Kmart, etc. Another likely culprit is old fuel. Many years ago (like 30) the fuel lasted nearly forever. But sometime since then, the fuel has been reformulated making it work better in the short term, but having a limited shelf-life. If your fuel is more than a year or two old, try some new fuel.
