Question about Intel Motherboard
Ho un pc IBM net vista con scheda madre LBL PN 32P2992 FRU PN 49P1599. Il mio PC ha un HARD DISK da 40 GB. E' possibile aggiungere un altro HARD Disk da 160GB. Non vorrei sostituire l'Hard disk originale in quanto non ho più i programmi originali da reistallare. Grazie Giuseppe
SOURCE:
  • 87 Answers
SOURCE: Domanda di supporto scheda video su P4VMM2
now this is the language which i cant understand! so if u can tell me in english den i might be helpful to u !
peace!
Posted on Nov 17, 2007
SOURCE: hard disk not detecting
When I click on the hard disk icon it provide a list of program through which the file will open.
Posted on Sep 26, 2008
hvpatel
  • 152 Answers
SOURCE: Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Posted on Jan 20, 2009
bluegreenash
  • 661 Answers
SOURCE: I am looking for a motherboard manual for an IBM Board
hi
this is the manual for the system that this board is from
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
I hope this helps
NetVista types 8181, 8182, 8301, 8303, 8304, 8305, 8306, 8307, 8308, 8309, 8310, 8311, 8312, 8313, 8314, 8315
in models
21U 21F 22U 31U 31F 31G 32U CTO 23G 11G 51U 51F 51G 52U 52S 52P 53U 53S 53P 61U 61F 41U 41F 54U 54F 54S 54P 81U 81S 81P E1U E1F E1S E1P 41G
Posted on Apr 24, 2009
konzzz
  • 255 Answers
SOURCE: regarding hard disk updation
you need to buy a new harddisk with much more capacity.but for the drivers, it can be downloaded
Posted on May 08, 2009
I need and driver for IBM FRU PN 49P1599.I can't find one.
It is motherboard from IBM Netvista 8305-43uhere is all information and drivers -
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-42869
Nov 15, 2012 | IBM FRU PN 49P1599 Desktop Motherboard
Devo installare windows 7 su un pc scheda madre p4pe ge
Non consigliato, la scheda madre ? troppo vecchia e non supporter? Windows 7 ne meno al minimo. Almeno ha bisogno di una nuova scheda video con DX9.2.
May 23, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Il mio amd sempron e molto lento nelle operazioni,il desktop sembra che ha dei problemi,come posso fare?
Che problemi presenta esattamente?
La lentezza nelle operazioni può essere causato da un fattore software o da un fattore hardware.
Se il problema è hardware si può risolvere facendo una scansione con l'antivirus e con un antimalware (per esempio Spybot search and destroy).
Se il problema è hardware potrebbe essere imputabile ad una cattiva ventilazione dei componenti del pc oppure ad un componente che sta cominciando a guastarsi
Apr 06, 2011 | Computers & Internet
SmartBase MP360 appena avviata per qualche secondo fa rumore di pettine contro acciaio e non funziona
Questo rumore clunking / rettifica di solito ? un ingranaggio inceppato o una barra di controllo provocando qualcosa da cedere il passo (di solito l'elastico con i denti su di essa dietro la testa). Ho risolto i problemi simili su HP e Epson e ogni volta che ha bisogno di una striscia gi? e un attento esame delle lavorazioni. con Epsons di solito era un ingranaggio che aveva saltato un dente e poi la tempistica era fuori causando un inceppamento. Con polipi iperplastici, di solito un frammento di carta nelle opere o inchiostro schizzato su uno dei tanti sensori ottici, facendo accadere le cose nell'ordine sbagliato. Il mio MP360 inceppata con i capi in sosta (ma senza clunking). Ci? ? stato causato da inchiostro secco mescolato con polvere di rendere il meccanismo di pulizia pigro e (in qualche modo) jamming la testa. Ho preso le coperte per spegnere la stampante (un lavoro lento) e pulito tutto, ri-ingrassate. problema scomparso. Attualmente ho le teste ammollo in una miscela di alcool, detersivo liquido e acqua per sbloccare le teste di nuovo.
Jan 19, 2011 | Canon Office Equipment & Supplies
Salve ho inserito la chiave di rete nel router belkin che ho acquistato e funziona ma ora ho un problema mentre il pc entra in automatico con il cell. IPhone ogni volta mi chiede la chiave di rete...
non solo emette segnali router Belkin e tutte le reti wireless dipendono da una singola password, controllare il prodotto in modo da poter ottenere Connected
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
Il mio Acer T180 non da più segni di vita nel senso che, collegando il cavo di alimentazione, non si gira nessuna ventola e non si accende nessuna spia L'unica prova che ho fatto è...
Sembra che il vostro alimentatore pu? essere morto, perdona il mio italiano, anche la if alimentazione non si accende non mean it effettivamente funziona, prima di cambiare la tensione, provare questo, scollegare il system, rimuovere la scheda madre battery, tenere premuto il potere pulsante per 30 secondi, rilasciare,, sostituire la batteria, plug-in e si accende,,, se quello non riesce, individuare i pin sulla scheda madre che il pulsante dell'alimentazione si collega anche, ci dovrebbe essere qualche altra cosa l? come bene, come reset, LED di alimentazione e HD LED, assicurarsi che il sistema ? collegato a sua volta e lo ob utilizzando un cacciavite tipo di lama e bridiging entrambi i perni di alimentazione con esso. I apoligise ma non sono molto bravo a itallian Quindi, se ho mescolato tutto mi perdoni ..
Sep 16, 2010 | Acer Aspireā„¢ T180 PC Desktop
Il problema consiste che hò disattivato il
Posso solo immaginare che questo è stato disattivato perché non vi è stata installata una scheda video nuova. Per ripristinare il computer, trovare la batteria sulla scheda madre. Vicino alla batteria ci sarà un ponticello. questo ponticello sarà reset del BIOS CMOS. Questo Tuen il tuo video
Mar 14, 2010 | MSI K9VGM-V Motherboard
K7s6a max processore monta
This is an english site, you can't expect to get answers to Italian questions, now can you?
Comunque, il massimo moltiplicatore è 12, la massima velocità di FSB è 166.
http://www.xbitlabs.com/articles/mainboards/display/kt333-sis745.html#sect6
Il problema è che quando gli tiri il collo a questi livello, il processore diventa instabile e NON ci sono due processori uguali: l'unica è provare. Nessuno può dirti "Il processore taldeitali regge 1.2 GHz" perché magari lui ha un processore venuto meglio e raffreddato a bestia, mentre se ci provi tu, il processore ti si frigge. Oppure gli accorci la vita:
http://it.wikipedia.org/wiki/Elettromigrazione
Puoi aumentare il moltiplicatore gradualmente e, se incontri instabilità, provare a compensare aumentando il Vcore a passettini. Ricorda che se lo aumenti troppo rischi di friggere il processore. Dopo ogni aumento, fai girare una mezz'ora winmemtest (o altro programma "stressa-CPU") monitorando la temperatura della CPU con SpeedFan. Se la temperatura si alza troppo, chiudi subito tutto.
Immagino tu abbia già provveduto a dotare la macchina di un buon dissipatore e pasta termoconduttiva appropriata, ma se no guarda qua:
http://www.overclockmania.net/
Spero di esserti stato utile ;-)
Oct 30, 2009 | EliteGroup K7S6A Motherboard
Intel Motherboard Logo
284 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
