EnGenius EOC-3220 (EOC3220) Logo
Posted on Mar 25, 2017
SENAO EOC-3220 EXT software hi i have senao EOC-3220 400mw AP the problem that suddenly the device just hang down - No signal and cant reach by IP- and when i tried to connect it by console modem null cable nothing appear on the screen i try hardware reset but still the same however the power LED is On and when i connect LAN the LAN LED is On but the system LED still off ,i think the software is curropt PS:i connect the cable with the same configruation on a same AP the system initialization appear on screen can i download a new software on it by console cable ? how to check if the memory IC is still working? even i cant reach the AP through network ? i dont know what to do , please HELP! A.R.H
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Feb 22, 2008
SOURCE: resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Anonymous
  • Posted on Mar 27, 2008
SOURCE: i made firmware 1.39 to SENAO ECO3220
hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Anonymous
  • 144 Answers
  • Posted on May 07, 2008
SOURCE: SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Anonymous
  • 611 Answers
  • Posted on Apr 17, 2009
SOURCE: how do i reset my engenius senao eoc 3220 outdoor
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Anonymous
  • 481 Answers
  • Posted on Oct 28, 2009
SOURCE: problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
1helpful
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Noy finding ip address senao wireless AP
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Problem using 2nd hand AP senao EOC3220 EXT
1helpful
How do i reset my engenius senao eoc 3220 outdoor radio
Senao USB wifi 802.11
I am afraid that I have had to make an assumption as to the precise modle that you have but the following link should be correct, it gives you the option to download drivers for the
Senau NUB362 (Ext)
http://www.senao.com/English/Default.aspx?TYPE=test.htm&PT=searchDownload1&sf1=D331&sf2=NUB-362(EXT)&sf3=&tv_TCAT_POS=0&CATNO0=D&IDX=3.2&CNT=1&CATNO1=D3
numerous drivers for different operating systems seem to be avaliable.
if I have chosen the worng type a pull down list is avaliable showing the differnt Senao product drivers avaliable.
2answers
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
hello!
2helpful
4answers
Resetting the senao eoc-3220 long range wireless access point/bridge
1helpful
3answers
I made firmware 1.39 to SENAO ECO3220
2answers
Senao 8610 not working
Are you saving your settings when you exit the setup screen?
Johnlgrn
Top EnGenius Computers & Internet Experts
john h
Krzysztof Tomasz
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
