Sony VPL-CX61 lamp/cover blink. Power on, it works. After about 10-20 seconds, it does not work, and lamp/cover led blink.
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Testimonial: "Thanks! And please tell me where is the lamp cover located."
hi,
u can see the lamp cover underside the projector . it is tighten with one screw. remove the screw.( that portion will be seperate from its body ,with small ventilation.)
Hi,I found the lamp cover. I removed and resetted it. But, it still not work. I will contact Sony service to fix it. Anyway, thanks a lot.
hi,
may be its door switch have problem. its contacts may be faulty.
ok
OPEN UR PROJECTOR YOU CAN SEE TWO PUSH BUTTON SWICHES ARE THERE ONE IS NEAR UR LAMP COVER AND ANOTHER IS UR AIR FILTER WITH A PAIR OF WIRES SHORT THEM AND START UR PROJECTOR UR PROBLAM WILL BE SOLVED SURE
