Honeywell HZ2200 Compact Heater Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a honeywell pro series eletric heater that does not go onto high heat the element does not get red.
Anonymous
Level 2:
Novelist:
  • Expert 224 Answers
  • Posted on Dec 20, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
224
Questions
0
Helped
92097
Points
482
Sounds like a burnt out element that needs replaced sorry!
What do the red lights on eletric ge hot water heater mean
Please post model and serial information to better help you with your problem. Not all GE water heaters are made the same or utilize the same controls throughout the years.
Honeywell RTH 6360 wiring and parameter issues We bought this tstat to keep our machine shop heated over weekends. Two wires coming from a Modine gas infrared. Red wire lands on R black wire lands on W....
The 6360 is a low voltage tstat. Sounds like you needed a high voltage tstat. With wires carefully separated and power on, test voltage to determine if you need a 24 volt or 110 volt tstat
My heater is not working at all only my power supply light is on
unplug the heater. remove the screws holding the control panel, pull the control out from the body of the heater enough to get the probes of an ohmmeter onto the connections that lead to the heating element. the ohmmeter should read less than 100 ohms. if the ohmmeter reads infinite ohms (open circuit), the heating element or the connections to it ate bad. if the heating element is bad, cheaper to buy a new heater. if the heating element is okay, repair connections or control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Kenmore 80 series electric dryer doesn't get hot
The eletrical heating element is most likely faulty (broken and open-circuit) and will need to be replaced: this is non-trivial exercise involving main and dangerous high voltage better left to a professional repairman.
Heater does not heat when turned on. indicator light stays red
check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
9helpful
2answers
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 • Dryers
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
