Firstly Check if your WIFI router is working by accessing the WIFI connection from another computer, tablet or phone.
If it does, then use the same WiFi connection settings that it has on your ARCHOS.
You could also try connecting your ARCHOS to a friend's WiFi network and if this works, change your access point parameters to similar ones.
OTHER TROUBLESHOOTING OPTIONS:
1. Check your WiFi router/modem documentation to see if it has a pairing button that needs to be pressed. Some modems have such a button that must be pressed the very first time you try to make a WiFi connection with a new device.
2. If you have to enter a password (a security code of type WEP or WPA) be very careful that you do not confuse a 1 and I (one and letter "I"), a 0 and O (zero and letter "O"), or U and V. These are common mistakes.
3. When entering a security code for your WiFi access, check the box "Show Password" which will allow you to see exactly what you are typing in. This will avoid any mistakes.
4. Some access points use what is known as MAC filtering. That means, the WiFi access point has a list of access numbers (every hardware device has a unique MAC number) which are the only ones allowed to access to the WiFi point. The person managing the WiFi modem/router should shut off this MAC filtering system to see if this solves the problem. It is recommended to shut off MAC filtering in general as this is now known to be an outdated and ineffective system for WiFi security. If you must use it, you can find your device's specific MAC address by going to Settings >Wireless & Networks > Wi-Fi settings > Menu > Advanced. It will look something like 00:16:dc:5e:9e:39.
5. Try temporarily shutting off the encryption system of your WiFi router/modem to see if the problem has to do with the encryption system you are using. The preferred encryption system is the WPA2.
Things to Check:
1. Please check if the wireless switch on your laptop is ON?
2. Are you able to see your wireless network in the list of connections?
If the answer for both of the above is yes, then Turn OFF & Turn ON the Modem/Router.
Please delete all the connections that are stored on your laptop's wireless settings/Wireless connections and retry connecting to your network.
On your modem/router, please remove any security passwords and make the network accessible by any one any try connecting to the network.If the connection is successful, then reprogram the modem / router with a password.
Another easy fix to find if the fault is actually with your laptop is to go to a free public wireless hotspot and see if your laptop connects to their network.If it dd, its not your Laptop but your wireless modem/router.
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Sure you can that. 1. you have new internet connection. need to configure the router according to internet connection type. it could be manually .. 2. set the wireless settings on the router again manually. then try to connect the router.
If you need my help the send me some information about the network. 1. when you connect your pc to modem what ip address you get. 2. what ip you get when u connect your pc to router. make hard wired in both condition.
For you to use the modem direct - you may need drivers - BUT connecting to a router does not require any drivers - and you should just be able to plug in and go
If wireless - then you may need to provide the wireless security key if the wireless is secure - and if the wireless is on the same SSID name as before that may cayse a problem - but you can renove the xp wireless profiles to overcome that
Wireless Profiles
- delete the preferred networks
start>control panel>network connections>
right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
you will then have to enter the wireless security key for any networks you connect to
If on a LAN connection - you may need to turn off the modem/router and PC - then turn on the modem - allow to settle and all the light to show normal status - turn on router and do the same then turn on the PC
Sure! Try this: 1 Turn your network off. Modem router, computer, printers etc. turn them off. 2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up. 3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up . 4. After this, turn on all computers, routers and etc... no particular order. This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything. 2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted. 3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip. After that, turn on any other routers, and the computers... This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well... Give it a try and let me know! K
if you set your dynalink's dhcp list up to a certain number (example: .1-.99). connect cat5 cable from dynalink lan port, into print server lan port. make sure print server can be setup as access point. if so, turn access point setting to on. make print server static ip address the next number outside of dhcp range (example: .100).
.100 ip address is the port number you should then be printing to, using a tcp/ip port.
if print server can be set up this way, then it now becomes wireless access point for all wireless devices. i am assuming, since you didn't mention it, that the dynalink is NOT wireless. if it is, the the print server just becomes another device on your existig network, taking the place of the network adapter the printer doesn't have. just set it up the same way you would set up another workstation on the network. except, make it static.
