Question about D-Link (DI-784) Wireless Router
What does it mean when the triangle light (second light from the left on this modem (WBR1310) is blinking, and how do I fix it?
  • D-Link Master
  • 7,733 Answers
Go to D-Link - TechSupport FAQ.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Dec 20, 2010
  • w_smith_29 Dec 21, 2010
    i also faced the same issues which you are facing and my friend told me about "ijinni technician" i contacted them at WWW dot ijinni dot COM.any issues. just open the website and you can chat with the experts who are Microsoft certified technicians and will fix the issue itself on the spot or u can call them through Skype or contact and for more visit their website as it is very user friendly website. just click on the chat as the response rate will be very fast from them and they have fixed my issues in no time.
SOURCE:
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
What does the second warning light on the lexmark printer e260dn mean? and how do you fix it?
We would like to know more about the second warning light you're referring to. Is it the second light from the left or from right side. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information if the light blinking, slow blinking or solid light.
For further assistance, please call Lexmark Technical Support.
Feb 23, 2011 | Lexmark E260dn Laser Printer
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
My modem randomly resets and no internet.
either the modem is going out or its a problem with your internet provider. before calling to complain to the internet provider. run down to your local walmart or electronics store and pickup a modern if you have the same issue its your internet provider.
i delt with a modem that was causing a similar issue. the problem ended up being the modem was running hot. i modified the case and added an external fan and the problem went away.
hope this helps. good luck
Mar 03, 2017 | Thomson RCA DCM245R Modem
Not able to configure my router
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 07, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Westwall modem Internet is solid red light
If the internet light is red, it means that the modem cannot get an ip connection from the ISP.
If your ISP has a PPPOE connection, most likely, the PPPOE password is not correct.
To ensure your settings, access the modem through a web browser. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, you will need to reset the modem. Just hold the reset button for 30 seconds. Then turn it off for 1 minute.
Try again to access the modem, under Configuration, click Edit beside My Connection. Type your ISP username and password then Save.
Hope this helps! Good luck!
Jan 24, 2010 | Westell Wirespeed LiteLine 6100...
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
May 28, 2009 | Westell Wirespeed LiteLine 6100...
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
May 07, 2009 | Actiontec (GT701) Modem
Blinking light means that firmware on your DSL modem just got updated. The modem is pinging the Networ/Computer connected to it. If you open your Modem Page 192.168.1.1 you will see the difference, unless you never have done it before.
Jan 25, 2009 | Westell Wirespeed LiteLine 6100...
Zoom X5 ADSL light not blinking
May be your ADSL modem has clapped out it sounds like it. You say you can connect via the PC modem that means the dialup is working......I imagine you have tried the ID logon and password for the ADSL also and it still wont connect. Try support at your ISP and if it still dont connect then it must be had it, you will need to buy another.
Aug 30, 2007 | Zoom 5551A Modem
Open Questions:
See all D-Link (DI-784) Wireless Router Questions
D-Link (DI-784) Wireless Router Logo
265 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
