SOURCE: Inconsistent printing.
The sensor tag is not well calibrated, press FEED, PAUSE and CANCEL, turn on the printer and release the keys when you move the label to print and let the end be calibrated.
Roberto Martinez
Mexico
[email protected]
SOURCE: Have X3 Zebra 140Xilll printers. These printers
You can get paper out messages if your media sensors are not calibrated. Go into the LCD menu and perform a "Media and Ribbon Calibrat". The LCD will tell you what to do step by step: Load backing, remove ribbon, load ribbon. If you are not using a ribon, just hit next. One reason that these sensor values can get out of whack is that your printer may be set to calibrate on head close or power up. Consider changing these values in the LCD to Power up = "no motion" and Head Close = "feed"
I would also suggest upgrading to the latest version of firmware from Zebra.com .
SOURCE: Our thermal label printer Zebra
That means that your settings are wrong or the commands are not transmitted.
You are probably in inline mode try to switch to page mode
SOURCE: Hello. I have a MK500
Hi, i work so hard to fix this software.....now i can run this software as a Self PriceChecker at Retail Store..... contact at [email protected] for full solution in C#, SQL Server 2008 or Novell Server
