SOURCE: Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
SOURCE: Describe your danby dwc283bls top
Hi,from your problem,it seems the problem is from the logic board,you can however use a mulimeter to read the voltage supplied by the board,if it reads a low amount of voltage it means the board need to be serviced and cleaned thoroughly,but if it reads no voltage at all meaning its not supplying no amount of power,it means the logical board is bad and needs to be replaced.
Thanks and take care
SOURCE: Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
E4 on danby designer wine cooler -
TEST your compressor: Cooler can be forced to operate and cool as a test.
Unplug unit from 115v receptacle.
Hold both temperature control buttons down.
Plug unit in 115v receptacle.
The cooler should start, but the thermostat will not stop the compressor. Now you got a freezer ! I do not know how to fix the E4 error yet.
