Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
A
Anonymous Posted on Dec 19, 2010
Looking for plug for water go in s3501 - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 68 Answers
  • Posted on Nov 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
68
Questions
0
Helped
67899
Points
79
I found this site that sells shark parts good luck i hope you find what your looking for!
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Jun 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
Helped
27928
Points
83
I know of this great site, that sells all kinds of replacement parts Shark/Euro-Pro included <a rel='nofollow' href="http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok">http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok</a>
Anonymous
Level 2:
Sniper:
  • Expert 67 Answers
Anonymous
Expert
Level 2:
Sniper:
Answers
67
Questions
0
Helped
54917
Points
190
<a rel='nofollow' href="http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok" target="_blank">Shark Parts</a>
Anonymous
Level 3:
  • Euro-Pro Master 43,501 Answers
  • Posted on Mar 05, 2011
Anonymous
Euro-Pro Master
Level 3:
Answers
43501
Questions
0
Helped
10835197
Points
101584
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
Shark S3501 model mop heats up but no steam or steaming sound
you might try a teaspoon of vinegar in the water. It may have a small plug from hard water.
1helpful
S3501 manual
Tap water will work fine, however, if your water is known to have a high calcium or lime content, that will, over time, build up in the tank and nozzle areas of the unit. Distilled water will eliminate that problem if you use it exclusively.
Took apart head of sharp steamer S3501; cannoat reassemble. Where can Iget a diagram of how to reassemble?
I just posted a video showing how I took apart and reassembled the S3501 to clear the heating core.
http://youtu.be/S4NglGXVv50
Nov 12, 2012 • Vacuums
Shark s3501 plugged
I had same problem with no steam... ready to throw in the dumpster!
I tried to it take apart. (kind of hard) still ready to throw it!
Then I thought about CLR!
I put about 1/2 cup in, turned on and let set for about 20 to 30 minutes.
I really did not think this would work but... Amazing! I actually got STEAM!!!!!!
Next I dumped out what was left, put in distilled water and ran for another 30 minutes on high.
Will use CLR again before final clean out and 2 full tanks of distilled water before I use again.
May 27, 2012 • Vacuums
60helpful
2answers
Shark steam mop s3501 no steam
On these steam mops you have to use distilled water, if you use tap water and do not have
a water softner, the feeder tubes that pull the water to create steam will be reduced in size
and clog up. the only other option is to take it apart, and replace the hoses, i used some
small fuel line with spring clamps that i bought at an auto supply, it works! good luck!
2answers
No steam comes out . I have Model S3501 shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
2answers
Shark S3501 steam mop will not make steam
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
