Kogi L9CH 19" Flat Panel LCD Monitor Logo
Anonymous Posted on Jul 31, 2017
I just installed an ATI Radeon hd 4560 video graphics card and when I rebooted my computer the monitor went into oversize Recommand Mode 1280x1024 and went blank. I rebooted in safe mode and changed the resolution back to 1024x768 to no avail it gave me the same thing upon reboot. I had to take the new video card out to get the monitor back. any suggestions on how to resolve this issue? Thanks in advance
2 Related Answers
Anonymous
  • 2517 Answers
  • Posted on Dec 19, 2010
SOURCE: I installed an ATI Radeon HD4650 video graphics
Need to proper installation for that video card. I hope you have the driver for that operating system.
Ekse
  • 13435 Answers
Hey,
install the latest drivers from http://support.amd.com/us/gpudownload/Pages/index.aspx
uninstall the drivers that you have installed now.
if the same problem happens after reboot with new drivers, hit F8 during start up to get advanced start up options and select Base Video, or VGA mode or similar, you will be starting up on 640x480 or 800x600, then change resolution to the 1280x1024 and 60Hz. most likely.
let me know how it goes.
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
4helpful
I have ATI RADEON 9600 Pro, (256 MB) graphic card and I'm looking to buy a new monitor; does anyone know what resolution my card supports? I can't find it anywhere. Thanks!
  • Supported Display Graphics UXGA (1600x1200),
    1152x870,
    SXGAW (1600x1024),
    1152x864,
    SXGA (1280x1024),
    SVGA (800x600),
    720x480,
    1856x1392,
    2048x1280,
    QXGA (2048x1536),
    VGA (640x480),
    XGA (1024x768),
    1280x960,
    HDTV (1920x1080),
    1792x1344,
    2048x1152,
    1920x1200,
    1920x1440
Found at: http://reviews.cnet.com/graphics-cards/ati-radeon-9600-pro/4507-8902_7-32107705.html?tag=mncolBtm;rnav
I i have a card 1 gb with DVI/VGA/TV-OUT and i need to show on COMPUTER SCREEN AND TV IN THE SAME TIME pls advice how?
Make sure you have the Catalyst Control Software installed and set to advanced mode. When you open the program and go to the settings for multiple monitors. There is a box that needs to be checked on the VGA option that allows it to be on always.Here is the support link where you can find the software http://www.amd.com/us/products/desktop/graphics/ati-radeon-hd-3000/hd-3400/Pages/ati-radeon-hd-3400-overview.aspx
Installed new video card, system reboots
your current graphics card settings is not set to the correct level to match your system, you can download ATI Catalyst software from this link:
after installing, you may have to restart your computer. when you restart, right click on the desktop and select (ATI catalyst), there you can adjust your graphic card features or you can use the recommended settings the software have adjusted for your graphic card by clicking on restore settings/defaults.
you should not encounter problems once you have installed the ATI software.
1helpful
When I plug in my Gigabyte Ati Radeon 2600 graphic accelerator in HP dx2300 computer I cannot boot win xp. There is no signal at all at monitor. There is no activity of hdd.
Boot the Windows in a safe mode and u8ninstall all the graphic drivers already installed - whether of on board graphic card or some other card and then restart windows & install the drivers for your HD2600XT.
Please do not forget to disable the on board graphic in the bios of the motherboard - after uninstalling all the previous drivers.
Good luck & happy viewing!
Diamond Radeon HD3870, 512MB DDR4
According to ATI this is a known issue. They refer problems to microsoft about this error as they say it is an o/s issue. Microsoft refers you back to ATI saying it is a thermal issue. I have an ATI card as well & have the same problem. Hopefully the next driver will fix this issue when released. Hope this helps.
ATI Rage mobility graphics card update for dualview
Display Driver
http://ati.amd.com/support/drivers/xp/radeonxprevious-xp.html 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
respond
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
instability
• Catalyst Control Center: Enabling pulldown setting may not work on all video
formats
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
My ATI RADEON HD 3870 over-clocked edition wont work. Plz help.
if your original graphic card was intecrated then u most first disable it in bios then u can use the new one
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Top Kogi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
