Question about Nordic Track C2255 Console (treadmill)
My C2255 will try to start rotating for a second then stop. The console stays lit and the buttons all beep but the motor will not work. If I cut the power and turn it back on it will do the same. Any ideas?
    Novelist:
  • 135 Answers
Remove the motor hood cover. Under the lid is a tech sheet. There you will find the service mode calibration procedures and an explanation of what the flashing LED means on the motor controller.
It sounds like an overcurrent shut down.
Listen carefully to the operation of the controller PCB. When start is pressed, you will hear a relay clik. Watch the motor for excessive sparking. Upon shutdown, you will hear it clik again (off).
Unplug the machine, disconnect one of the motor wires, either red or black. Plug in the machine and start it again, listening to the controller. if they relay now stays on, I would suspect a defective motor (drawing too much current).
Posted on Dec 19, 2010
SOURCE:
Golds Gym 420 belt stop working but the rest is working like the incline and the console but the running belt is not working is there a button combination i can press to reset it ? it seems its just on...
Remove bottom motor hood. Is the red KLED lit on the controller? When you press start does it beep and does the timer start? No LED replace controller. No beep or timer start console keypad is bad.
Jul 13, 2016 | Exercise & Fitness
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
Nov 10, 2012 | Frigidaire Affinity ATF8000FS
Treadmill won't start. Console works but when push start or any of the buttons it beeps and nothing happens. It incline, change speed. I unplugged and restarted but nothing.
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Oct 29, 2011 | Nordic Track C2255 Console (treadmill)
My ps3 stopped working and i use an HDMI chord, i tried holding down the button for 10 seconds then turning it on and still nothing shows up. I checked the chord and it works. Should i plug in the red,...
I think you may be holding the power button down for too long. Instead of holding it down for 10 seconds only hold it down until you hear a second beep (it will beep once as soon as you press it). The console should stay on after the second beep and the display should initialise.
Try this method with both HDMI and AV lead (red white and yellow lead)
I hope this helps and thank you for using FixYa
Sep 02, 2010 | Sony Playstation 3 (PS3) Console
F2 code
Hi, F2 code on the Kenmore indicates a problem with either of the control board and the user interface board. Run the console and indicators diagnostic test mode to find out.
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press START within five seconds when "dt" shows on the display. All indicators in display are lit and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the functions. The indicators switch on and off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the control board, the user interface board, and the connection between them.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector and the terminals thoroughly with brush and alcohol.
  • Reconnect and disconnect the connector several times.
  • Reinstall the console and reconnect power.
  • If the problem is not resolved, replace the user interface board.
  • If the problem is still not resolved with the replacement of the user interface board, replace the control board. You may also replace both board at the same time and keep the old good board as a spare.
Take care
Jun 20, 2010 | Kenmore Oasis 27042 Top Load Washer
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Clean the connector thoroughly to ensure a good connection.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Nordic track c2255 console displays FF and will not do anything
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
Jul 25, 2009 | Nordic Track Exercise & Fitness
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Nordic Track C2255 Console (treadmill) Logo
243 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
