There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete)
Here is a couple of videos that should help understand how towel bars
Print I hope this helps you,good luck.Randy
Removal & Installation
Instrument Panel
Fig. View of front floor console and shift bezel
Fig. View of front floor console, showing attaching screws
Fig. View of floor brace, attaching nuts, center brace, and floor bracket
