Master
- Posted on Dec 19, 2010
Re: I have a C2150 4 gal compressor from Porter cable...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
It should run on a 15 amp circuit, but I am not using any extension cord. I have tried using this compressor on several jobs with and without cords. Sometimes it will work with my 50' 10 gauge cord on one job and the next job it will not work even though its pluged right in to the wall. I think I got a lemon. The further the plug is from the panel, the less likely it is to work. Does someone make device that I can add to this compressor that would reduce the startup draw?
