The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
The PS3 video resolution setting is too high for the TV to work, please see your PS3 user manual on how to lower the resolution to the native resolution of this TV.
Change your video resolution to match the new monitor. Right click in a blank area on your desktop go to properties and change your resolution (in XP). In Vista or Windows 7, after right clicking on your desktop, choose Screen Resolution (about the 3rd one up from the bottom of choices).
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence. Should be between $200 to $300 for a repair. Blessings, A/V Media Guy
yes, stop using a plasma TV as a computer monitor. Using the TV this way is an invitation to phosphur burn which these are very prone to. The issue you describe is due to the limitations of the TVs scaler circuit to properly center the image in 720P.
you have not mention the model of lg 32" what i suggest is lower the resolution of your hp pc tp 800 by 600 and gradualy increase the res to get the picture which matches the plasma
hope this will solve your problem
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
