V6310US (offically retired at HP = no support)
first is carbon dating the thing, 2008 h3ll deal.
answer is (was) 2007 made, 10 years old now
and is in fact subject to the SOLDBALLS from H3LL failures
(aka Nvidia horror GPU)
does it turn on, main battery out, (hint they short and overload it)
yes,/no
does the fan turn and not packed in lint as all are this old.?
test 3: try a new coin RTC battery yet, for $3 ,if this battery goes dead so does BIOS go NUTS, (even black screens of *****)
hint the GPU dont just fall out like my great HP8540w does.
no, low end PCs its on the main board, soldered down
no ,you wont magically get reflow to work. sorry.
if you twist the case or press ******* the J key
will the PC turn on (fan on?) hint, that is tech trick.
rtm? see where that is>? free book no scalping here, !!!
PDF page 129 covers simple RTC swap in, do that now.
https://www.manualslib.com/manual/273302/Hp-Compaq-Presario-Presario-V6000.html
this laptop came as Intel based (CORE) or AMD based processors. wild differences. that.
onboard, video GPU is,, was... this.
NVIDIA GeForce 7150M (i see folks showing this failed)
sorry for you if it's a bad mobo, $$$
the 15 to 20 causes of Black screens of ***** and tests. to find it.
http://pcdied.com/black-screen.html#Laptop
SOURCE: blank screen problem witn presario v5000
Remove HD (optional, just in case u shake up the unit too much),
(i)
Remove battery,
remove 2-3 screws found in the battery comparment
(ii)
Pry up the keyboard bezel/power button cover by accessing slots above F2 & PAUSE keys,
it will feel extremely tight but work it a little,
try not damage your keyboard (try and pry/separate the back of the cover first).
(iii)
Look top-left,
u'll see a cable leading from the motherboard to the display
(iv)
CAREFULLY unplug the white connector and replug FULLY FULLY.
PLEASE pry and push the white connector housing ONLY not the fine wires.
THAT SHOULD BE IT!
If not i can take u to more advanced testing with meter and probes.
SOURCE: How reset bios password
hi I have a problem with a password to in windows I erased my password but now I restared and ask me a pasword of administer so I do not have any now ¿how can I get in windows ?
SOURCE: cannot control sound when booting...
Sohanad, look in control panel under sounds. There a setting in there that you might have to check/uncheck, inorder not to hear sound when headphone are used.
SOURCE: hi there i have a Hp Compaq presario cq50 and it
Hard Drive is bad and probably needs to be replaced.
Good Luck...
SOURCE: no sound on my compaq presario V2000 amd turion 64
I am unaware of the exact model of your notebook so please find them listed here with all drivers you will need.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
Processor Type 754-pin (uPGA); 638-pin (uPGA)*
Support Processor
AMD Turion™ 64 X2 Dual Core
Processor,
AMD Turion™ 64 Processor
(25/35W series),
Mobile AMD
Sempron™ (25W series)
Those are the ones that your laptop supports
