SOURCE: Hugo Boss watch
go to this link and find your nearest Movado Group(they make and repair the watches) service centre; http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User4%20LIKE%20'_S%25' They can probably answer your question over the phone or e-mail, if not they certainly could if you could get the watch inspected. Most jewellers would also probably know - sometimes the serial number can be marked inside the watch, but I found no information online about your model that discusses this. Hope this helps, hope it's real :)
SOURCE: ebel sportwave chrongraph
It;s probably a difective movement mechinism.
Ed
NC Electronic
Mills, Wyoming
SOURCE: My boss has a Citizen
good morning ! to set the Eco Drive Skyhawk citizen watch,full the crown carefully wind it slowly until you reach the correct time after that push the crown back to normal possition, if the hand is turning back to the wrong time just press the button on the up side until the turn to the correct time,thank you ! god bless !...
SOURCE: Cannot start new Hugo Boss Watch
check the battery, if it still wont work then try shaking it and see if there is something loss inside if there is, you bought the watch with already a technical problem
SORRY!!!
SOURCE: Bulova Marine Star with chronograph. The minute
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
