Question about Sony KV-36XBR450 36" TV
Sony kv36xbr450 - menu screen comes on and off by it self. It's not remote control. I checked. How can I fix that?
    Genius:
  • 1,112 Answers
HI
This may be due to a faulty A Board, one way to verify is to disconnect the keypad from the main board and check if this is still happening, if so then the A-board is the problem, this is the board with the microprocessor is on, The micro processor may be faulty. you can try resetting the unit back to factory default by starting with the tv power off then hit the DISPLAY button on the remote then Number 5 , then Volume down then power button, you have to do this all within 5 seconds or it will not work. Once you are in the service hit the number 8 key to reset, TV will shut down and come back on by itself and be on channel 3. Any setting you may have set will be erased and the unit will be back to factory as when you brought it,. IF this does not help then consider replacing the A board. It my not be avaiable any more in which case time for a new TV..
Posted on Dec 19, 2010
6ya staff
SOURCE:
The Bravia menu comes up across my screen. It will go off when I hit any button on the remote & then come back on. the model # is KDL-32EX301. How do I get it to go away?
It's caused by the Bravia Sync feature. It doesn't always connect correctly. When there are issues then attempts to sync up cause the menu to appear.
The solution is to switch off Bravia Sync.
Go in to the TV's set-up menu, and choose HDMI Set-up.
Scroll down the menu list and choose Control for HDMI, then set the menu option to OFF
Let us know if that fixes the problem for you.
Sep 15, 2014 | Sony BRAVIA KDL-32EX301 32" LCD TV - 16:9...
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
9.1.2. Exit
This is straight out of the service manual.
Regards,
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Samsung BD-C 5500 blue ray player DVD tray stays closed after suggested fixes
Sounds like a security code setting in the manufacture's setting. Manufacturers have different terms and different ways of doing things in the their menu settings that can often be confusing to users. All players come with a remote control with a menu button. If you have a users manual check it out for the manufacturers interoperations list of the abbreviations you observe on screen what they mean. Ask you self what does that mean and so on and look it up in the manual for help. If you haven't one you can consult search engines for the manual. When you press the remote control menu button an on screen menu displays plastered in front of the players welcome desk top. If you are familiar with toggling though your cell phone or computer menus search for settings and observe if there is any ON/OFF feature buttons that may be provided to switch of the annoying feature.
Apr 18, 2014 | Samsung Bd-c5500 Dvd Blu-ray Disc Player...
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
How do you remove the self check on a panasonic viera 37 in lcd tv?
Hello:
This procedure will bring up the self test screen and reset the unit to factory settings for you.
First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Oct 10, 2011 | Panasonic Viera TC-37LZ85 LCD TV
Menu will not come up. Channel will not change. No remote.
brendee89,
I did not get who the manufacture was of the tv but you may want to see if one or more of
the menue buttons are stuck down on the tv's front panel. This has been a common cause of
problems with Mitsubishi and Sony tv's. It could also cause volume to go up by it's self, no menue
functions, no power up and or no remote control functions to work.
Hope this helps,
Skyman
Jun 16, 2009 | GE 19GT317 19" TV
I have trinitron Sony Television.. i got some problem with my TV, the Vertical screen size gone out of focus... I want to know about remote control Commander Codes from which i can resolve my problem and...
I think what your asking is for an on screen service menu?? That wont fix your problem. It sounds like you have a vertical height problem where the screen doesnt fill the entire screen with the Picture. The adjustments wont go out like that for no reason and all by them selfs. The vertical sweep IC went bad and is going to have to be replaced. This is not a job for the end user. You should call an experienced tech to assist you with this repair. Good Luck
Aug 12, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KV-36XBR450 36" TV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
