Here's an owner's manual:
User Guide Usually, if the machine breaks thread, it is because it is threaded incorrectly, the tension is too tight, or there could be a bad needle. Make sure you are using the correct needle and inserting it properly.
Check to make sure the thread coming from the spool is not wrapped around something that it shouldn't, ie the spool pin or the thread tree.
Unthread everything, RAISE the presser foot, then rethread from the very beginning making sure the threads seat properly in the tension disks.
Thread each thread in order as instructed (usually the upper looper first and the lower looper second with the tail draped over the top of the first looper). Pull at least 6 inches of thread tail of all three threads and lay them all in a straight line under the presser foot extending toward the back of the machine.
BE SURE to check your threading sequence against the instruction manual diagram since missing one thread guide will cause problems.
Set all the tension dials to the midway point to test your stitching. HINT: it helps to thread with 3 different colors so you can determine which threads are presenting a problem.
When a thread breaks, it is best to rethread everything from the beginning. Sergers are very finicky machines and even if you try to rethread only the broken thread, they will generally refuse to work.
