SOURCE: DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
SOURCE: toshiba tv/ dvd /won't open
Unplug the TV ...wait 30 seconds then plug back in. Worked fine.
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
SOURCE: TV/DVD player will not recognize DVD disks
Please check these things:
1. Are you placing the disk with correct side on the tray.
2. Is your DVd player has a region lock for the DVDs you are playing.
If above question are not true then you must go to the reapir man.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
SOURCE: Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
