There are quite a few variations of motor and pulley combinations. You can change the motor and pulley based on your needs, however do not over-clock the recommended rpm or the pump. Check the specifications of the pump to determine the max rpm . Usually the pulley on the motor will depend on the rpm of the motor. Check the rpm of the present motor to determing the rpm of the pump with current set-up, and compare to the motor you are considering. Motor rpm vary from around 850 to 3450 so pulley size is quite important. Good holidays
