SOURCE: LG RH7823W - Timer recorded audio out of sync
Try this site reportedly the fix is here
http://mybroadband.co.za/vb/showthread.php?t=24182&page=6
SOURCE: RH1888 - wont start
Check the ribbon connecting to the HARD Drive...you will need to open the case up..
be careful as the ribbon is very delicate
SOURCE: the dvd recorder and it hdd can't record since hdd full
Miss Fouzia Morocco
pls try to format all HDD first backup ur data by connecting the dvd recorder to pc then format ur hdd it will help lemme know
SOURCE: Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
SOURCE: Iomega HDD 160 GB
Hi
If it is connected to the mains ,make sure it's correctly connected.
Also try another USB port on the computer.
If it used to switch on before or even make sounds to show that it was working and now it doesnt then it's either a problem with the harddrive case or the drive itself.
To retrieve the information on it(if the problem is infact the case) then you will need to open the case and remove the harddrive from it and then buy an external USB case for it ,or if you are technically good with computers attach it internally to the computer.
Good Luck
Please rate answer if it helped ,if not then let us know.
